(quoted from post at 09:42:01 05/17/19)
(quoted from post at 12:32:52 05/17/19)
Soooo, the ballast resistor was used in the old points system to drop the voltage to the coil. That old coil wire is disconnected now because with the Pertronix kit, the coils no longer connects to negative 6volts DC, the coil now connects to positive ground. So that old coil wire coming from the ballast to the coil has been disconnected on both ends and wrapped up with electrical tape on each end for now.
And the Pertronix instructions for their black wire just says to wire it to the ignition, it does not say to use or not use the ballast. So when I tried wiring to the ballast it won t start or run that way, I think the Pertronix needs full battery voltage to run.
" I think the Pertronix needs full battery voltage to run." You are correct on that point!
Only two lines in Pertronix 1247P6 wiring instructions and when you followed them all was well, but...............then when you didn't and started experimenting with the ballast resistor is when trouble began.
Don't do that.
Do exactly as instructions say.
WIRING:
1. Attach the ignition switch wire directly to the Ignitor black wire.
2. Use 18 ga or larger wire, connect the coil positive terminal (identified in instruction sheet drawing) to an engine ground.
You are done wiring.
No ballast resistor mentioned.
No ballast resistor needed or used.
