RGR
Just curious, has anyone tried that adapter for spin on oil filter for the N series tractor, does it work or don't waste your money.
You do know that only a bit of the oil flow is bled off for the filter, right? Couldn't be farther from "full flow"...
(quoted from post at 17:00:55 05/15/19) Just curious, has anyone tried that adapter for spin on oil filter for the N series tractor, does it work or don't waste your money.
ork, some better than others, but unless you change filters often (me maybe once a year), I personally stick with canister.
I would say any benefit is insignificant , but like Starbucks coffee its your money . I like the idea of a vertical spin on filter and plan on using it mostly for personal convenience , I don't like fooling with the canister filters , same for Electronic Ignition . I would guess that technically you can get a finer micron size spin on filter but I doubt you would ever see any improvement .
No I haven't ,but if I did I would want a metering hole same size as the factory hole. The hole can be in the filter or the adapter.
