Company Logo Shop Now
TractorLinks.com
shifter grinding
brash_vs
05-14-2019 16:33:59
i have a 9n and whenever it moves the shifter rattles on the tranny gears, my pin is broken but i dont believe thats the main problem. i believe the ball and socket are worn enough to lower the shifter to rub the gears, is there a fix like adding shims or ? or do i have to get a whole new cover
brash_vs
05-15-2019 15:42:00
 Re: shifter grinding in reply to brash_vs, 05-14-2019 16:33:59
this was what i was thinking i had to do. on his post i dont understand what he uses for a shim, he says a machine bearing?
HCooke
05-15-2019 06:10:01
I have fixed several of these. I take the trans cover off, Take it to a welder who builds up the slot, and then I cut it down to the original dimension.
John in Mich
05-15-2019 07:29:11
 Re: shifter grinding in reply to HCooke, 05-15-2019 06:10:01
My experience was the pocket was also worn. Steel shift ball on aluminum pocket. At the same time I replaced the steering gears in the box. I made a jig to align the gears and the steering wheel.
Kirk-NJ
05-15-2019 00:02:42
I have seen some pretty crude temp fixes for this over the years. Seen one where a guy used a longer pin and added a couple of washers to the outside to prop it up and then wrapped with a radiator clamp to hold it together then cut and try to hide it with a shifter boot and some duct tape. Anyway on the N tractor site in the How to section scroll down to transmission for the fix.If you can find it send me an email for the link.
brash_vs
05-14-2019 18:34:48
i put the new roll pin in and it is a little better but still drags. its like the shifter leans away from where the pin is ridding, i believe the socket where the ball on the shifter rides is worn out. unless i can build that area up i will need a new housing
what someone needs to do is make an insert where it gets pressed down inside and the existing hole
John in Mich
05-15-2019 05:29:32
 Re: shifter grinding in reply to brash_vs, 05-14-2019 18:34:48
One of the things that tried before molding some epoxy into the socket was a Delta single lever faucet washer upside down. I did not like the movement feel.
TheOldHokie
05-14-2019 17:54:04
He will probably have better luck searching for a .25 x 1.5 roll pin ;-)
TOH
John in Mich
05-14-2019 17:41:23
I have experienced the same thing. I had a welder build up the top of the socket and then I cut a new grove for the pin. I did try some shims but did not like the effect on the lever.
I pulled the cover and clamped a small board to the bottom. A friend mixed some epoxy and we molded it into the socket with a steel ball bearing the same size as the ball of the shift shaft. I then drilled out the hole. My email is open if you would like to see some pictures.
brash_vs
05-14-2019 17:40:45
i was going to but is there that much pressure on the pin to hold up the shifter
Den N Ms
05-14-2019 18:03:09
 Re: shifter grinding in reply to brash_vs, 05-14-2019 17:40:45
Brash,Is your top cover aluminum or is it cast steel?
Den N Ms
05-14-2019 17:37:03
Brash,Replace the broken pin PIN,6.35mm OD x 38.1mm L part No: 9N7221B.Check the spring and it's retainer
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
