TSX 33 Carburetor
JGraves
New User
Would someone be so kind as to explain the Choke Poppet Valve? Also, does the bowl drain plug have a gasket/o-ring?
The choke poppet valves opens to let air in so that you do not over choke it when it starts.
The bowl drain plug does not have a gasket or anything on it. it is a tapered pipe plug.
