I think I'm just about at my wits end with this tractor. I feel like I've hit all the points necessary to get it to start but it just won't.. It's a 48 8n.
When I try to start it it will try to fire and run (very poorly) on the first attempt and for about 5 seconds then shut off. Upon trying to restart its a no go from there.
When I parked it last fall it ran fine but I haven't been able to get it to start all winter.
Here's the things I've checked:
Spark is fine.
Gas is getting to the carb and filling the bowl.
Points on distributior is set correctly and they don't appear burnt
Compression is about 60-70
The gas was fresh last fall and treated so I doubt that it but that's the only thing I feel I haven't tried is some fresh gas.
If someone could give me another idea that would be great.
Thank you
Spark is fine.
Thank you
