My 2N is almost impossible to start when the weather is colder. During the summer months it does not appear that hard to start. After craking it for awhile in the cld it stutters and tries to start but never really gets going. I've tried any where from very little throttle to 1/3 throttle to 1/2 throttle to full throttle. Tried with and without choke and with modulating the choke. After a few minutes no matter what I try I notice gas coming out the the carbyretor intake. Last imte I checked, this summer had good sparl. Waiting for the Michigna weather to warm up amd will pull the front mount distrutor and check it and replace the points and condensor. Will also do a compression check as I believe the compression was a little low last fall, but don't remember what it was. Am not looking at doing an engine rebuild as I would need ot take off the front loader and just don't use the tracotr that much. If it turns out to be a major repair I may just get rid of it. Not really able to do much on it in the current pole barn it's in as no heat and all of my tools aare in the other pole barn.
Open to any ideas and suggestions.
THanks,
Bill
THanks,
Bill
