In Nov. 2018 I successfully converted my 8N to 12 volts. Engine started successfully multiple times. Recently when I attempted to start it I found the
relatively new battery was dead. I replaced the battery and immediately after connecting battery cables, the wire from ammeter to the starter solenoid
began to smoke and insulation burned. I quickly removed battery cable to avoid a fire. I found this wire was the only one to burn. I?m surprised since
everything worked fine immediately after conversion but something has changed. Can someone please help me analyze this problem.
Clay
Clay
