A few months ago I received a lot of help from this forum (see https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=nboard&th=1035425) and was able to get my Golden Jubilee hydraulics in operating condition at least in implement control after removing the unloading valve, replacing it's o-ring, putting on a new baffle plate gasket, and adjusting all linkages. I've since plowed a garden area with a two bottom plow and the hydraulics lift it just fine.
I've now moved on to a fencing project. In what has taken way too much time, I've only got about 10 holes dug, and had to dig the auger out 3 times after it's gotten stuck. What happens is the PTO bogs down and stalls the tractor if the ground is at all wet. When starting back up, I can't get the PTO to turn without stalling and also can't get the hydraulics to lift the auger. After the third time, the hydraulics wouldn't lift the auger even after digging it out and having it completely clear or any dirt. I could force the implement up and the hydraulics will hold it, just not lift it on its own.
There was a lot of air bubbles on the hydraulic dip stick and I suspected the culprit was the relief valve in the bottom of the housing. I removed the auger and pulled in garage with the plan to follow my repair manual and remove the valve. After spending some time trying to adjust the carburetor, decide to try the hydraulics. It now seems to work fine. Now air bubbles on dipstick, and was able to hook up to plow and lift it just fine.
Long post, I know, but any advice on (1) how well a Jubilee should be able to handle a 12" post hole auger, or (2) if I should replace remove/clean or replace the relief valve?
