Rodman31
New User
Im new to the tractor. Its a 52 8n the guy i bought it from said he relaced the cylinder kit from ebay. It raises with out a load but it wont lift the blade. I took the side plate off while running and i have dripping coming from it. Thanks for any help
Dripping isn't usually a major problem. A steady stream under load is. You have a few other possibilities, like a blown pressure valve or dirty pump. Make sure
it's in position control. And try the quadrant adjustment. But possibly the repair wasn't done correctly. A new piston in a worn cylinder doesn't get you much.
Or the bore could be over-honed. Or the O-ring was installed correctly.
75 Tips
