Guys I need some electrical help again.
I'm using an el cheapo meter to check ohms on the 12v and 6v coils.Measuring from the primary stud on top of the coil to the tab that would go to the dist.cap.I'm reading 2.7 ohms on the 6v coil and 4.0 on the 12v coil.I also have another coil from a diff manufactor that reads 3.3 ohms.I suspect the 3.3 is a 12v coil attempt.All coils are new out of the box.What is correct for both 6 and 12v coils?Does this measurement have anything to do with voltage goinig to the coil and if so,how much MORE resistance does the system require to keep either 12v or 6v coil and resistor from burning up?Thanks for all help. don b
