Jubilee hydraulic valve rebuild kit?
Asher
New User
Can anyone point me to a soft parts rebuild kit for the hydraulic valve body assembly? Every time I try searching it directs me to pump rebuild kits.
Also is it a good idea to replace the pressure relief valve while I'm in there or is it a waste of money?
Thanks in advance.
Howdy Asher. By soft parts are you referring to seals and gaskets? This site lists lots of individual parts for the hydraulic lift. But I don't see anything like a kit. On the left column of the screen, up toward the top under Market Place, click on Tractor Parts, then Ford, then NAA or Jubilee. Then look for hydraulic lift parts.
Thanks Jim, yes seals/gaskets I was hoping that something was already packaged up. I'm use to automotive stuff, you need to rebuild a auto tranny and you can just by a soft parts package that includes everything you need.
Thanks for the direction, I wanted to make sure my money was well spent and going to good sources.
Thanks again
I have never been into a NAA lift cover.
I think the kit comes with a leather backing washer for the lift piston o-ring its been updated to a neoprene washer # 5200T359 are the generic # 330BU9. I would diffidently use the updated backing washer.
The other thing of concern is the unloader valve the o-ring are what ever they use is has to be sized correctly.
I would study up on lift cover removal there was a post on issues with an NAA a month are so back JMOR covered issues with an NAA well...
Put "acorn" in your search bar...
