OK, hopefully to avoid the issue I had last time, I'd like to hear from those who have actually [u:6cc46234d6]been there, and done that[/u:6cc46234d6].
If you have opinions on why to do it, or if you worked on a 67 JD rear axle, or if you want to chatter about a six cylinder engine debate, please leave that for AFTER the answers to the 'rate the rear outer axle seal R&R job'.
Tractor is a 48 Ford 8N. I do have lube leak on the left side affecting brake action. I know I can do the brake reline, but have not tackled the rear seal. I have access to a fairly large 3 jaw puller, and some heavy/large wrenches. How long will my shade-tree skills take for this work?
