Over the years I have acquired several of these Toro series II units. I am needing several parts to finish some of my projects. These have what I believe is a Ford 8NNN industrial motor(very similar to the 8n motor). All that I have torn down do have sleeves, no governor, and a timing cover that is also the motor mount. This also then requires a different oil pan. I am looking for part numbers for the timing cover with motor mount, oil pan, and carburetor. I haven't been able to locate part numbers to begin my search. Any thoughts? These are 1942-1949. The carb is just opposite that of the 8n. The throttle attachment is on the out side rather than next to the block. I appreciate any help or direction. Thanks
