noweirdbeard
New User
Hey guys. I finally got my new old tractor running after rewiring it and converting to a 12 volt neg. ground.
Its not running very well though and its got me scratching my head.
I put new points and condenser, rotor, plugs, coil. The cap and wires looked ok so I didnt change those. Seems to have a good strong spark on my tester.
It was running with the old carb at first, but I figured that was my problem so I bought a new carb and it ran just the same .
Its starts up quick and idles ok, but if I try to raise the rpm it sputters and dies or pops thru the carb.
I bypassed the fuel tank and am just running a tiny aux tank.
Air cleaner is not hooked up.
Checked firing order, its correct.
I made a bad video of it if you want to check it out and see what you think.
https://youtu.be/c6oGGSjJc68
