riddlebthis
New User
I have a 9N that will not turn over. Doesn't even budge. I attached both of the starters I have to the battery at different times to verify they are working and they both are. I have taken jumper cables from my truck to the battery terminals and can get it to turn over rather slowly (not fast enough to kick off) and faster if I pull spark plug(s).
The tractor is converted to 12v.
I have replaced:
All of the wiring (except for the battery terminals)
Alternator
Ammeter
Key Switch
Push Button Switch
Starter
Both Resistor Blocks
and also converted points/condenser to electronic ignition
Here is the wiring diagram I used (1 wire alternator)
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwjevpedlO_fAhUDb60KHe5LByEQjRx6BAgBEAU&url=%2Furl%3Fsa%3Di%26source%3Dimages%26cd%3D%26ved%3D2ahUKEwjevpedlO_fAhUDb60KHe5LByEQjRx6BAgBEAU%26url%3Dhttp%253A%252F%252F23.23.terranut.store%252Fwire%252Fford-9n-wiring.html%26psig%3DAOvVaw1Yj5eT0ricdTHV8b2-pfg0%26ust%3D1547620069356236&psig=AOvVaw1Yj5eT0ricdTHV8b2-pfg0&ust=1547620069356236
I have verified spark and fuel.
Any help would be greatly appreciated. Thanks.
I have replaced:
Alternator
Ammeter
Key Switch
Push Button Switch
Starter
