Went to start my front mount 8N after it has been sitting a spell. It is a 12 volt system. No fire to plugs. Pulled coil
and distributor. Cleaned and set points to .015. I did not check voltage before. Now. There is
voltage drop at coil. When hot wire is connected./ When hot wire to coil is not connected . Full 12
plus volts to coil./ When hot wire to coil is connected. Voltage drops to 3.0 volts at coil./Possibly a bad
coil? Running inline resistor. I accidentally touched it and it burned the crap out of my finger.
I don't know if it is a 12 or 6 volt coil. How can you tell if it is a 12 volt or 6 volt? Thanks.
