Resister needed?
T L
I am changing a 8n to 12 volts. I have purchased a 12 volt coil. Do I need to add a resister from the switch to the coil?
Yes the original resister is there. I was affraid to use it because I thought it would burn out being a 6 volt resister. Thanks for the advice. When it warms up a little I will try to finish the conversion.
(quoted from post at 16:34:36 01/11/19) I am changing a 8n to 12 volts. I have purchased a 12 volt coil. Do I need to add a resister from the switch to the coil?
You only need the original resistor no extra ones. Here is a diagram JMOR made hope it helps.
" I thought it would burn out being a 6 volt resister."
Nope. 6v or 12v doesn't matter to this resistor. It's there to reduce current to the coil when the tractor is running.
75 Tips
