Randy K. Crump
Ford 2N engine rebuilt with new pistons, rings, sleeves and valves. I think the compression is too low. Here are my compression test results. I cranked it 5 strokes which is the first number and last number, then placed oil in cylinder which is the last number.
Cylinder 1 - 80 - 105 - 135
Cylinder 2 - 60 - 80 - 100
Cylinder 3 - 60 - 90 - 115
Cylinder 4 - 90 - 115 - 125
Mechanic that did the overhaul no longer available. I have the head off. How do I remove valves and do they need to be ground?
THANKS!
THANKS!
