(quoted from post at 14:23:01 11/21/18) There won't be any contamination of the transmission or differential oil. The NAA has it's own hydraulic sump.
(quoted from post at 12:30:48 11/22/18) That wasn't me that asked. How dare I question you though.
(quoted from post at 14:53:41 11/23/18) TOH; I may have missed your point where you explicitly cited seal leakage as a potential problem. What caused me to respond was that you recommend an 80 wt. UTF fluid in the hydraulic sump and that made me think that you might have the N tractors mixed up with the NAA. But you didn't. Now here is a question for you, would that 80 wt. UYF work well in low temperatures like 20 degrees or colder? I don't know if my old vane type pump could handle that.
(quoted from post at 15:18:50 11/24/18) Isn't the sump open from trans to final drive on a jubilee as the 8n ? I was thinking that was the difference between the jub. & the naa.
(quoted from post at 16:32:30 11/24/18) Thank you for clearing that up.I have yet to take apart the back
end of my Jub. and i am more familiar the 8-n.I currently have
mineral gear oil in my 8-n.but yes it is stiff in cold
weather.In my jubilee should I run The mineral gear oil in the
trans and Traveler UTF in the rear drive that also doubles as
the hyd. sump?Or would the UTF be acceptable in both? Thank you
for your input.....
(quoted from post at 17:51:32 11/24/18) TOH, thanks for the lesson on oils. With the possibility of the seals starting to leak at any time, if they already aren't, I think I will change my oils out to UTF.
(quoted from post at 13:07:22 11/25/18) Nice tool! I'm going to use it to compare UTF and SAE 90 mineral oil (the two that are talked about all the time.
According to Valvoline, their SAE 90 GL-1 straight mineral gear oil has the following properties:
API Service GL-1 SAE 90
Viscosity @ 100° C, cSt 17.0
Viscosity @ 40° C, cSt 189.7
A graph showing these characteristics is quite enlightening as to low temperature performance. No wonder the hydraulics are sluggish in the winter with mineral oil!
