There are 2 likely culprits in causing your problem: a weak spark and old fuel. And, a few other possibilities that I'll get to in a minute.
No matter what else you do, the battery must be fully charged *. A float charger is helpful; not a trickle charger, but a float charger. (I use Battery Tenders on all my tractors; ** see below) Are you using a float charger? If not, check the specific gravity in your battery; it could be discharged.
Clean grounds & battery terminals are always important. Don?t forget to loosen the starter from the block (see tip # 36) and polish the block & all starter mating surfaces w/ sandpaper to insure a good electrical ground.
If you can?t remember the last time you replaced the battery cables, it?s time to do it. Just because the terminals are clean doesn?t mean there is no corrosion under the insulation. And, this is another case where size matters (see tip # 41)
A charged battery, clean grounds & new cables aren?t going to mean much if the tractor needs a tune-up. At a minimum, every fall, remove the cap, check bushing wear , check the points for pitting or burning, re-gap them & put a dab of lube on the cam. (BTW?..if you?ve wondered why some folks get years of use out of a set of points??.this is one of the reasons).
While water in gas today is unusual because of all the ethanol, it?s not unheard of. The problem stems from what?s called ?phase separation? in the gasoline. The alcohol binds to the water & it settles in the bottom of your tank. The way to mitigate that is to keep the tank FULL, use the full 10 gallons in 30 days, or add a fuel stabilizer. Less air means less moisture in the tank for the alcohol to absorb. If you?re lucky enough to live in a state where you can buy ethanol free gas (and it does not require a bank loan to do it) then add alcohol to the gasoline. (e.g., ?HEET?) Otherwise, the 10% ethanol in the gas is more than enough to deal w/ the water. But, it's more likely that you have summer gas in it. The refineries change the blends in the Spring & Fall.
Things that aren?t all that important in warm weather become serious when it gets cold?like timing. A few degrees of timing either way at 60 or 70* isn?t likely to result in a ?no-start? situation. Well, it can at 10 or 20*. Check the timing! (yes, you can set the timing on a front distributor)
Distributor gaskets are important on a sidemount & critical on a frontmount. As is the gasket under the coil. Just like with the battery cables?.if you can?t remember when you replaced the gaskets, do it this year.
Push the clutch in when you start the engine (tip # 29)
Oil viscosity can make a difference. If the tractor is going to be consistently operated below 20* F, switch to SAE 10w30; at 0* go to SAE 5w30.
Pull the air cleaner cup & check for water which will turn to ice.
This tip won?t make it start easier, but it will make it run better: turn the main jet out ? to 1 full turn for cold weather operating. Cold air is denser so you need a richer mixture.
While each N has its own starting sequence, none of them will start well by just yanking out the choke rod & holding it out for 5 or 10 seconds while the engine cranks. This is a gravity fuel system on a low compression engine; it is easily flooded by too much choke.
Try this:
Key on, gas on 2 full turns, clutch in, 3/4 throttle, press the starter button. Let it crank for at least 3 - 4 seconds before you pull the choke rod. Then, don't hold it out for more than 2 or 3 seconds.
If you find out it will not start w/o excessive choking, you have problems.
* Your battery loses 33 percent of its power when the temperature dips below freezing, and over 50 percent of its power when the temperature falls below zero. A fully charged battery will not freeze until -76?F; however, a fully discharged battery can start to freeze at 32?F. So??keep the battery fully charged!
**Battery Tender at Walmart:
https://www.walmart.com/ip/Battery-Tender-Junior-High-Efficiency-12V-Charger
/36007111?wmlspartner=wmtlabs&adid=22222222222024671621&wmlspartner=wmtlabs&
wl0=e&wl1=o&wl2=c&wl3=10359583927&wl4=kwd-1103060408167&wl12=36007111_0&wl14
=battery%20tender%20walmart&veh=sem
75 Tips
