Copper gasket spray??
Lynn Patrick
I've never used it before, but this '43 2N rebuild has been giving me fits, so I think I want to use the copper gasket spray on a metal head gasket. My problem is I doubt the young woman who runs the local parts store will have any idea what I'm talking about. What exactly should I ask for? (Maybe I don't know any more about it than she does!)
Thanks!
I've used it on all my 4-cylinder flat head Fords.
Just show her the link.....or order it off of Amazon for half the cost.
https://www.amazon.com/Permatex-80697-Gasket-Hi-Temp-Adhesive/dp/B000HBNUDQ/ref=sr_1_2?ie=UTF8&qid=1542728907&sr=8-2&keywords=copper+coat+spray
75 Tips
I've done it dry and used it. if there are screwdriver or scratches from a previous owner rough handing the head or block, then
I use the copper spray.
never failed so far.
Lynn,If I had any question about the head gasket sealing on a N I would use a FelPro Part #7277B perma torque Head gasket.Then save the steel one for a later project.FelPro blue #7277B,use the best available.
FelPro
This will probably start a bunch of replies, but all I've ever used is plain old silver spray paint on a metal head gasket. Never had a failure.
(quote) This will probably start a bunch of replies, but all I've ever used is plain old silver spray paint on a metal head gasket. Never had a failure.(quote)
I was kind of hoping it WOULD start some comments! I did the same one time w/a cheap white spray bomb on a fiber gasket & had no leaks.
(quoted from post at 12:02:56 11/20/18) Lynn,If I had any question about the head gasket sealing on a N I would use a FelPro Part #7277B perma torque Head gasket.Then save the steel one for a later project.FelPro blue #7277B,use the best available.
FelPro
Yep , Ditto that . I try to save money when I can , but unless I am doing a weekend patch job I will gladly spend $18 on a Felpro head gasket . Most part stores can order one and get it the next day .
I took one apart that the PO had tried to use a used metal head
gasket and white RTV caulk. For some reason, it did not seal. :shock:
I used a new metal gasket and copper coat on that one. Sealed fine.
Still, I prefer the FelPro soft gaskets too.
(quoted from post at 23:11:57 11/20/18) I took one apart that the PO had tried to use a used metal head
i'm surprised to learn u got a tractor from hd6gtom.
