Torque Value for Right Anchor Pin on our NAA
FarmerHR
The right anchor pin on our NAA was loose and leaking oil. Thhe right trumpet is off and ready to tighten the nut inside the rear end. Have not been able to
find the torque specification.
Could you tell what torque to use ?
Thank you !
Assuming it's the same torque as the N lift pin, torque the nut on the new pin to 150 lbs before you put the cotter key in. Wipe the new trumpet gaskets w/ warm water until they are sufficiently pliable to stretch over the studs w/o breaking. Let them set a few minutes before you put them on. Make sure you use your favorite gasket sealer. Torque the 11 trumpet studs to 40 lbs.
75 Tips
