jbullfrog63
New User
Have i believe to be a 49 or so 8n, front mount 12 v electrical, 12v coil. Have been doing a complete refurbish of this tractor. Have new fuel tank, fuel cap, sediment bowl assembly, fuel line. Old marvel (aftermarket) carb was wonky. Constantly flooded and ran like crap. Rebuilt twice to same outcome. Float either stuck open and flooded or stuck closed and starved. Bought new aftermarket marvel carb...same problem. Unscrewed drain plug to check fuel flow and it was cross threaded....drain plug fell to ground taking all known threads with it.
Purchased new made in USA zenith 13876 carb. Out of box and floats stuck closed. No fuel to the bowl. Return carb. Ordered another 13876 and returned faulty carb. Received the next zenith put new carb on and floats stuck open gas pours from screen in bottom of carb. Tractor will sputter but not run.
Just for giggles i check spark and spark will jump 3/16" gap every time with bright blue spark.
Also should be noted it has a fresh reman governor as the old one was destroyed.
Sediment bowl shows no debree. That coupled with everything in the fuel system is new leaves me to believe floats are not sticking because of debree.
Any ideas? Is my carburetor luck THAT bad or am i missing something?
What are symptoms of stuck valves? Would this cause the flooding of carb?
