Copperhead don't play
Just bought a 8n where the PO had removed the transmission cover and the shifter forks and the oil. Apparently the transmission had locked up and he attempted to fix it. I can not move anything in the trans but the half-inch rods that slide back and forth. When trying to rock the tractor using the tires, there is no play or clicking.
Should I be able to slide the gears or shifting rings in the transmission with a pry bar?
Am I going to have to remove the transmission?
Thanks in advance for any advice.
P.S. It came with the original owners operation manual. I have never seen one before. He also had the receipts from the dealer for the engine rebuild in 1988. And, all parts and repairs over the years.
