Hello folk's, I have found the location where the serial plate used to be just to the right of the starter (two rivets in the block, no plate). The numbers stamped into the block at the serial location are illegible.
The only numbers I can find are located just below the location of the serial plate and it has 8N-B stamped in big letters.
Is there a way to try and get an approximate date from this unit without serial info?
