Loose anchor pin
FarmerHR
Had the same situation with my NAA. You might try the following: Remove the trumpet. Remove the cotter pin from the inside nut. Remove the inner nut. Mine was loose enough that it only required finger pressure. Once the inner nut is off, the pin will probably fall right out. If not, a few tunks will cause it to fall out. Now the pin can be held in a vise or similar device so you can put pressure on the outer nut to remove it. Hope this helps.
