Hey Guys,
New to the old Fords and just looking to see if i can get some advice on where to go with my 8N. I got it given to me and it hasnt ran in about 8 years, ran fine when it was put away. Your forums have been helpful as i have been trying to fix it up so i will let you guys know what i have done so far.
Pulled the carb- it was in pretty rough shape so i bought a new carb for it
Drained the oil and put in new oil and filter- running straight 30 weight
Pulled off air filter housing cleaned it all out and put it back together with new oil in the bottom resevoir
Pulled the rad off and flushed it as well as the block and remounted it with fresh coolant
Wasnt getting spark so put in new points, condensor and distributor which fixed my spark issue as well as putting in new plugs- Autolite 437 which i got from you guys
New belt
Pulled off the gas tank and cleaned it out- replaced the sediment bowl assembly and cleaned out all the fuel lines
This is what i have done so far. It has the 12V conversion single wire system on it and i also am using a new battery while trying to get it running.I got everything back together today and am not sure where to go from here, i got it to blow me a few puffs of smoke and sounded like it was trying to start but then didnt get much after that, pulled off the fuel line to the carb and checked the filter and that seemed to be fine, plugs are wet and definatly getting fuel and pulled off each plug and wire and retested for spark which i still had. Now because this is a new carb i wasnt a hundred percent sure on the settings for the idle and power jets so tried a few different configurations and couldnt get anything. From what ive seen my power should be 1-2 counterclockwise truns out and my air about the same? no idea if this is correct so any help on that would be great, not sure if i am flooding the bowl and the motor with the wrong settings or if it is another issue. 2 other concerns i have are there is a squeak coming from the motor and im not sure where or if this has to do why she wont run. its not the belt cause i removed it and still have the issue. Sounds like some people on here say the water pump but it sounds like a bearing to me and is definatly coming from the motor. 2nd is a hole in my exhaust pipe just after it leaves the manifold- not sure if these motors require alot of backpressure and this is messing with things or if it is a non issue. Anwyas any help would be great, thanks!
New belt
