Wiring an 8n
Yes, they do. Start with #4 and work down from there. Sometimes a little baby powder
helps. Coil wire can also be in that tube.
YES, the wiring loom holds the harness with plug wires, coil wire, and generator wires. It isn't hard at all to feed thru. The OEM plug wires never used rubber boots on the plug ends. That makes feeding thru the loom easier. Dennis Carpenter and AGRI-Services make new OEM exact-as-original wiring harnesses. Today's aftermarket plug wires (TISCO, for example) include rubber boots for the plugs. Leave them off until you get wires thru loom.
Tim *PloughNman* Daley(MI)
