Brokegunner
New User
Hey guys
I've only had my 2N for less than a week and I'm thinking it has so much wrong with it that maybe I'm better off finding another one to restore and use this one for parts?
So I went to look at one today and I'm super confused because there are features on it (or missing from it) that are confusing to me.
First of all, the seller called it a 1950 but I believe this one is a 1939 to 1941 9n because of the I-beam bars to the front axle. I checked the engine block serial number and it is showing up as a 2N from 1946.
As far as I can tell, it's been pieced together from multiple tractors so I'm just trying to figure out what the years of the parts are I guess.
So here's where it gets weird...
On the front of the steering gear housing I expected to see the starter switch but there's no provision for a start switch. I checked in front of the gear shift and there's no start switch there like I have on my 2N.
The dash appears to be a thick aluminum casting but it is broken. The rear fenders have 2 grooves in them which I thought points to a 1939 9n.
The PTO cover doesn't seem to be covering a pto... it looks solid, unless the coats of paint are covering the threads. Is it possible there is no PTO?
It looks like there was a hole in the differential case at one time, and I noticed none of the axle tubes have the usual casting numbers anywhere.
Are any of these features indicative of a certain era? Clearly the engine is 1946 but the other features seem very different and I don't know enough to see the clues the features point to.
I noticed the engine block has H126 cast near the starter, which I think means the engine was made on Aug 12 1946. It sure doesn't match up with the rest of the tractor.
Any help would be much appreciated.
Thanks!
Thanks!
