My 1953 Ford 8N had been running great but with good usage time and bad gas caused the carb the need to be rebuilt, which I did and even replaced it with a new one. I am able to get the engine started cold by using full choke and having it crank for a bit. Once I get it on, it will either begin to idle for about 45 seconds then die or the full speed wont go past 1800 RPM unless I manually move the governor but will hesitate and act like its going to die when I crank it from a slow idle to full throttle. The governor does have some play in the larger arm that connects to the carb by it being able to wobble towards or away from the engine aka side to side horizontally. If the tractor dies or I shut it off after it warms up, I am not able to get it started again unless I close the choke fully and crank for a while or I end up having to wait for a bit because the carb is flooded. I have checked for spark, checked to make sure all the points on the spark plugs and distributor are 0.025, replaced the spark plugs, installed a new carb and played with all the settings on the carb with no luck. So I am lost on what to do here, as it doesn't want to run smoothly or have enough power to run a brush hog which we did all the time prior to the carb getting jammed up. Any suggestions are welcome. a I really need to mow soon and without it working makes cutting 120 acres very hard to do.
