tiresharkdb7
It's an 850.
This is with the tractor off.
Fuel flows normal when the sediment bowl is not in place.
When I put it back on, tighten it down, and then open the fuel valve, no fuel will flow into the bowl. I have to loosen the sediment bowl a little, which lets the fuel start flowing, and once it fills up I tighten it back.
Is this normal? I feel like in the past it would fill up just from gravity, even if I had the bowl screwed in real tight, but I cant remember. I can start the tractor and it 'seems' to run ok, but I have to fiddle with the choke a bit.
I guess when the tractor is running it creates a vacuum and sucks the fuel in? Or is something screwy going on, and should it flow freely even if the sediment bowl is screwed on tight?
Hope I have explained it well... I can take a video.
