Caroline Chamblin
I have been mowing after the previous problems that were electrical in nature got solved, distributor was maladjusted. Tractor was running well. After a month of dry weather and no mowing, I went out to mow. Sediment bowl leaks like a sieve at the top where it seals with the cork gasket to the metal housing. I have replaced that cork gasket before successfully. I thought well I will replace it again. Didn't solve the problem this time. I have a few photos here. The screen and cork gasket I got at my parts place (not tractor supply, but not YT either) has a screen with offset hole. Mine has center piece so the old screen was cut with scissors. What do y'all think I should do next?
I see the open/shut fuel valve looks wet with gas. That has not looked wet before. However what I see leaking is around the bowl rim and down the sides of the bowl.
