new to posting but long time reader of posts. normally i'm able to search around and find what i'm looking for but not this time.I have a late 8n with a zenith carb,when moving the throttle lever,the engine rpm's would not start to increase until appox 1/2 way to max travel and under load there was no rpm increase. At some point in it's history this tractor had hit something hard enough to bend the sheet metal,push the radiator into the fan,even bent the hood where it screws to the instrument panel. some of the radiator tubes had been soldered closed,yes it ran hot even to the point of the gas in the tank boiling,the gas cap had been vented and the hole in top of tank was open.I added a temp gauge,new radiator,water pump,6 blade fan(from a bent 4 blade)and shroud so got a governor too. It now stays around 180* BUT, with the throttle lever and engine at idle, moving the lever appox 1" takes the engine to full speed,also the governor does not increase rpm's. I recently inherited this and trying to get in working condition. Looked at another 8n's throttle linkage/movement and it appears the same as mine. Sorry for the rambling, just trying to provide any info as it wandered into my mind. Any thoughts would be appreciated. Thanks Steve
