Hobo,NC
- Location
- Sanford, NC
I keep picking up this busted coil and going to throw it in the trash so played with it...
Mark it in this spot white dot and drill into it a couple inches. This is to locate the hole once you drill thru the bottom.
Flip it over and drill right beside the tang I used a end mill started the hole and finished up with a drill bit. You want to kiss the terminal post thats is were you are going to solider a wire to, to connect your coil wire.
I forgot to take a pix after I solderer the wires
I then just drillerd it out good to break the inside connections and to have a little room for the wires... The goop is plastic weld/epoxy.
I got around to putting Battery maintainers on my tractors under the shed I thought 3 would fit the power strip but they did not. Norther tool has are had them on sale $19.
So maid this up to screw to the wall for the outer one.
