hello all,
I knew I had what I figured was asbestos under the right running board for muffler heat protection, but as I was at ground level working on something else, I saw the asbestos (is that what it is) pad is , or for me, I should say was, in some sort of metal sleeve or shelf welded underneath. I can't tell if it was entirely encased or not as most of it is rusted away with the asbestos just sort of dangling underneath. Nothing came up when I searched for it, so wondering what you guys do to fix this.
a. do you grind off the old cover, if that's what it was and weld on a new one or maybe make so it attaches with the four support bolts?
thanks.
thanks.
