Roger in Iowa
8N hydraulics will not work when in "Draft" mode with draft lever in the down position. Doesn't do a thing, no noise, no attempt to raise the plow, nothing.
Hydraulics work with the draft lever in the up position. You have to manually work the control lever when plowing.
Yes the pto was engaged and clutch up in both situations. Also the control lever was adjusted thru its full range.
Fluid was changed when the pto shaft was changed, but it had the problem before. Did not find a lot of gunk in the bottom of the transmission, etc. What is going on?
