I Need Some Quick Advise, please!
NCmau
52 8N. I am trying to remove the pump for a gasket replacement.
PTO shaft, the two inspection covers and the 9 bolts are out. The pump dropped about 1/8” out all the way around . I used a chisel gently to break it open but I am having hard time to drop it any further. The front seems like is hanging up on something. I am trying not to pry it too hard before I do some damage. Is there a better method that I am using?
A jack is under the pump if she decides to drop.
(quoted from post at 17:01:32 10/03/18) After rear is down a bit, slide it toward rear in order to get the front out.
Thanks JMOR. Little things not in manuals and only acquired by experience!
