My battery sizzles
Goat Boy
I have an N9 Ford Tractor. It has been converted to a12 volt with alternator. It has no spark recently. I found there was no voltage getting to the coil. Which was because there was no wire coming off the key ignition. It looked like someone pulled it off. There was also an old wire heading straight to the positive terminal that broke that was connected to the resister that connected to the wire that ran to the coil. So I connected the resister to the key ignition. It started up multiple times and ran. Then I went to replace the ignition switch cause it was not working. I have been doing screw driver starts for a while. After replacing it I put the terminals back on the battery but it sparks and sizzles. Why is the battery getting fried all of a sudden?
(quoted from post at 14:30:36 09/29/18) I have an N9 Ford Tractor. It has been converted to a12 volt with alternator. It has no spark recently. I found there was no voltage getting to the coil. Which was because there was no wire coming off the key ignition. It looked like someone pulled it off. There was also an old wire heading straight to the positive terminal that broke that was connected to the resister that connected to the wire that ran to the coil. So I connected the resister to the key ignition. It started up multiple times and ran. Then I went to replace the ignition switch cause it was not working. I have been doing screw driver starts for a while. After replacing it I put the terminals back on the battery but it sparks and sizzles. Why is the battery getting fried all of a sudden?
Some place you have a wire going directly to ground. I would suggest that you remove all old wiring and buy a wiring harness to fit you 12 volt needs.
As R Geiger said, you have a short to ground.
See tip # 42.
Google "wiring diagrams JMOR". Find the diagram for your specific tractor & wire it accordingly.
75 Tips
Does is spark and sizzle as soon as you install the cables, or when you attempt to start the engine?
Be aware batteries can and do explode.
NASTY.
And if you have sparking or sizzling at the battery a battery explosion becomes even more likely.
First off, I'd never buy any tractor part from TSC.
You need a 12v coil and the oem ballast resistor. That's it. No other resistors. See tip # 30.
You can get both the oem ballast resistor & correct coil here.
But I'd suggest getting it wired correctly first.
75 Tips
(quoted from post at 22:10:03 09/29/18)
[i:3d7ac05073]"It only sizzles when I push starter button"[/i:3d7ac05073]
check your battery cables and battery posts. sounds like the connection that's sizzling is dirty/loose.
Is it possible that something at the starter is grounding it out? Everything is hooked up but when I push the starter button it stays to sizzle and the engine doesn't turn.
Also, I noticed the starter relay that I just bought has continuity from the back end to one side of the starter relay.
The sizzling is because of a poor connection.
Could be between the cable end and post, or the cable and and the wire inside it could be corroded and not making contact. (Failed battery cable.)
Or, a connection INSIDE the battery could be cracked loose.
Be CAREFUL, batteries generate hydrogen, and a spark can cause them to grenade.
If the battery has a failed internal connection, an explosion is even more likely.
When working with this, keep your face back from the battery, and were eye and face protection.
To go a bit farther, you MAY still have another issue with a component such as the solenoid or starter, with with good connections at the battery and a good battery, that shouldn't cause sizzling at the battery.
OK. I might just replace battery and the ground and starter cable then. See if that helps. My wife wouldn't be happy if I screwed up my face!
Really appreciate the info and the warning. I'll let you all know.
So I connected the resister to the key ignition. It started up multiple times and ran. [b:92cb2b4ed5]Then I went to replace the ignition switch cause it was not working. [/b:92cb2b4ed5]<snip> After replacing it I put the terminals back on the battery but it sparks and sizzles. Why is the battery getting fried all of a sudden?
It ran fine, then you replaced the ignition switch. I would start there.
You can troubleshoot with a test light and see where the power is "getting lost" before throwing parts at it.
Of course, if the cables are "past their prime" it certainly can't hurt to replace them.
Was gonna say to be sure and use some honk'in big ones, then I remembered this is a 12 Volt conversion, so 2 or even 4 gauge should do the job.
You've mucked up the wiring and/or it wasn't correct to begin with. A 'sizzling' battery would indicate something isn't wired correctly. Don't guess it can get costly if done wrong and you let the smoke out of something. 12V switch over jobs are more prone to incorrect wiring setups, many done by guys who don't have a clue, but either way if not properly wired, either will fail as is in your case. First, disconnect the battery. Next is to go thru the entire wiring system using "WIRING PICTOGRAMS BY JMOR" as a reference guide. See above post on where to get a free copy. Also use your original essential manuals for OEM wiring diagrams. You say it is a 9N switched to 12V. So, you have a front mount distributor, a 12V battery, OEM ballast resistor, ammeter, OEM key switch, 1-wire starter with no solenoid, an alternator, either a 1-wire or a 3-wire type, and no generator or cutout. Is that correct? Your coil could be 6V or 12V -which is it? Download a copy of Bruce(VA)'s 75 tips as well.
FORD 9N/2N OEM WIRING DIAGRAM:
Tim *PloughNman* Daley(MI)
I have a coil with about 1.7 ohms resistance so I think 12 volt.
I have no oem ballast resistor. Most of the wires are connected to one side of the ampmeter instead. Then to the key, then through a resistor and to the coil. It is a one wire alternator. I will re wire correctly and see how It works. I put brand new battery cables on too and it still sizzles.
So I will try it again after I rewire with the new diagram.
(quoted from post at 09:08:34 10/01/18) I have a coil with about 1.7 ohms resistance so I think 12 volt.
I really don't know what you mean when you say it sizzles. if you have direct short, a wire should be getting real hot real fast and start smmoking.
(quoted from post at 17:25:59 10/01/18) Bubbling and smoking. First bubbles and steam then smoke
Is that with the tractor running or not running? A battery can do that when being charged or overcharged.
(quoted from post at 08:22:24 10/01/18) You've mucked up the wiring and/or it wasn't correct to begin with. A 'sizzling' battery would indicate something isn't wired correctly.
" A 'sizzling' battery would indicate something isn't wired correctly. "
Timmy, in one of his posts he said it only sizzles when he attempts to crank it.
That is almost always a sign of a dirty/acid infused connection at the battery.
Also, if he's got a short in the ignition circuit, a wire would smoke and burn off LONG before a good battery would "sizzle".
Even a short in the starter area would have the full length of the battery cables DARNED hot before you'd notice anything unusual ("sizzling" at the battery).
Unless he's got some MONSTER battery cables!
It will be interesting to hear what's REALLY going on!
Well I retooled the battery cables with 1 gauge cables. Brand
new. Still when I try and push the button to stay her up the
battery stays a bioilin. I ordered a wiring balister. There is
some weird things about the wiring. It's definitely not correct!
But it was staying fine before.
(quoted from post at 21:12:18 10/01/18) Well I retooled the battery cables with 1 gauge cables. Brand
Suggestion......instead of rebuilding the tractor one part at a time.....why not just remove the battery and take it to a parts store for a load test? The technical term for the condition of your battery is " dead as Kelseys nuts".
So replaced the battery rewired according to diagram and now starts like a dream. I think I over charged the last battery. It fried it. Thanks for all the help
(quoted from post at 21:03:59 10/04/18) So replaced the battery rewired according to diagram and now starts like a dream. I think I over charged the last battery. It fried it. Thanks for all the help
You are DARNED lucky you didn't have a battery explosion!
Yeah. I'm glad I had some people who knew a thing or two to
help me out. Otherwise it could have happened!
