Working the hydraulics. Original issues: leaking cylinder, jerking up-lift and bottom links too high.
Here is what I did:
Installed new cylinder and NAA piston. Ground cylinder for draft mechanism clearance.
Checked alignment of top cover mechanism.
With pump in place, removed all 4 valves from chamber, garden-pump pressure wash with kerosene base degreaser [b:d247f60419]several times[/b:d247f60419], instant flow of liquid when control valves shifted back and forth. (I made sure all valve components were properly re-installed)
Installed new safety valve.
Adjusted the quadrant where the pilot hole touches the pump housing when touch control is at top as outlined in the IT manual.
Lift now is working nice and smooth. The lift arm, however, is not lowering enough, 13.5 inches from ground and a total of 21 inch travel. The arm reached its maximum lower travel. I am just wondering if the previous owner did not adjust the arms high for a specific operation. (Mechanic shop using tractor to move vehicles). The arms still have a good one and half inches before they hit the axle. It looks like the arms could be removed and repositioned maybe few splines for a lower position. I do not see anything in the manual that deal with this. Is this doable? The mechanism of the lift cover is adjusted where it it should be. Right now I do not have any answers.
P.S. I had difficult time reinstalling the top cover. It would just not slide enough forward to match the bolt holes. It seems the newly installed cylinder was sticking out a smidgen. Finally what I did is loosened the cylinder four bolts and so I was able to bolt the cover. After that I tightened the cylinder bolts, but they were tight to get the required torque. I suspect the cylinder casting was to close for the bolt square head, I guess if I have remove the cover next time I will grind one side of the bolt head.
Here is what I did:
