searching for hydraulic cylinder
IndiRon
I have a Wagner loader on an 8n. The single bucket cylinder needs to be replaced and I cannot find one. Any suggestions for a source?
Just get the lengths - fully extended and fully retracted, the barrel size and the pin size on the ends.
Then just buy a cheap tie rod cylinder at Fleet Farm or some such.
Well that makes sense...it is a unique looking cylinder, could be hard to find I'll hit a couple farm stores soon and see what's out there.
Common Sense wins again. Thanks.
(quoted from post at 19:19:49 09/26/18) I have a Wagner loader on an 8n. The single bucket cylinder needs to be replaced and I cannot find one. Any suggestions for a source?
Unless it has unique mounting setup a generic cylinder is the way to go.
TOH
Measure up the required dimensions and surf on over to SurplusCenter.com.
There's so many variables you may not find exactly what you need there, but it's worth a look, at least.
I did just as Old Hoakie and Udog suggest and worked just fine I couldn't get the exact length extended and retracted but close.
(quoted from post at 19:59:50 09/26/18) Well that makes sense...it is a unique looking cylinder, could be hard to find I'll hit a couple farm stores soon and see what's out there.
I think you will find a better selection [b:40d5c41577]and[/b:40d5c41577] price at:
Surplus Center
TOH
