Re: Carb rebuild kit
(quoted from post at 22:53:46 09/25/18) Mikes Carbs sell Made in the USA parts, just google.
ot saying it is not rue but I could find nothing on their site that says anything about the parts being made in The USA. Viton tips on float needles.
The neoprene packing is intended to be installed (lip facing OUT) on the throttle shaft, the felt packing and brass retainer are for the choke shaft.
It sounds like the throttle shaft has worn into the top carb housing. This is not rare at all, I have had a few like that my self. Easy way is to find a new top but yours can be repaired by enlarging the hole and installing a sleeve. The sleeves can be purchased from a full line M/S parts supplier. Great care must be taken when re-sizing the carb top as being cast it will not drill evenly and using a good drill press vice or a jig will make it easier. Or if it is not a large gap you could try a fuel resistant epoxy to fill the gap.
