Ford NAA front wheels shimmy
Danny Boyz
07-31-2018 18:45:43
When I take the Ford NAA down the road FAST the front tires & steering wheel shimmy just awful , Is this an adjustment on the steering box & how do I get it to stop.
Den N Ms
08-01-2018 08:09:33
 Re: Ford NAA front wheels shimmy in reply to Danny Boyz, 07-31-2018 18:45:43
Danny,Check the steering box,wheel bearings,spindels and rod ends for slop and looseness.Set the toe in to 1/4",very important to stop wheel shake.
soundguy
08-01-2018 06:50:47
next time you do this, put your toes on the steering rods at the sector arms. does the shimmy go away?
Yes? then you have some play in rear draglinks and probably need a backlash adjustment on the steering..
No? then you minght have some tie rod end, front hub / bearing play, possibly knotted tire or bent rims.
Some? then all of the above are possible.
hd6gtom
07-31-2018 19:16:49
What kind of tires do you have on the front of it? Single rib or very over inflated 3 ribs will cause that. Worn out steering box, loose tie rod ends, etc can cause it too.
