Minneapolis Moline Tractors Discussion Forum
Did MM ever use a big
fastfarmall
11-08-2023 07:38:47
Hi guys, did MM ever use a wide fender on a R or Z, there wide like a Case Standard Tractor,but these have a little triangle tool box, near the bottom ,back side,and one has a rope trip, holder or a clip, that i never have seen before, I been told before long time ago,that they are ford fender's? But these are yellow!!!
T.R.K.
11-08-2023 17:07:54
 Re: Did MM ever use a big in reply to fastfarmall, 11-08-2023 07:38:47
The only place I have ever seen the fender you describe with the tool box at the lower rear was on a Fordson. Back in my childhood (When 'old tractors' were pretty much Fordsons and McCormicks, there were a few around here. I don't think I have seen one at a show in several years.
They may have been aftermarket offerings for the Fordson. Lots of other manufacturers offered 'improvements' for Fordson tractors as the tractor itself was pretty basic.
That does not mean you havent seen them on a MM. A lot can get changed or swapped in 75+ years on these old tractors.
molinegb
11-08-2023 07:51:10
R only had the flat vertical fender until 50's when had small clams. Z used flat top one early model standards and crown on universals. Later Z only had small clams then ribbed ones. No big wheatlands like on U or G.
fastfarmall
11-08-2023 15:43:22
 Re: Did MM ever use a big in reply to molinegb, 11-08-2023 07:51:10
OK thanks GB, your the man!!!!
