Minneapolis Moline Tractors Discussion Forum
UTU hydraulic pump
jr1983
11-06-2023 14:08:45
I have a UTU with a leaking hydraulic pump. The fluid is spraying out between the plate that the pressure and return lines thread into and the next section. Im told there is a Quad ring in there. Does anybody have a part number or a size?
Ill John
11-06-2023 16:12:50
 Re: UTU hydraulic pump in reply to jr1983, 11-06-2023 14:08:45
call Welters, get a gasket and O-rings, 417-498-6496 When you
get it repaired, dont hold the valve past the sroke
jr1983
11-06-2023 18:05:38
 Re: UTU hydraulic pump in reply to Ill John, 11-06-2023 16:12:50
It has a flow divider and a charlynn power steering hooked to it. Did that cause a failure?
Ill John
11-07-2023 06:16:40
 Re: UTU hydraulic pump in reply to jr1983, 11-06-2023 18:05:38
doubt it, on mine, always happened when I held the lever too long causing it to hit the pressure relief
