Minneapolis Moline Tractors Discussion Forum
U water pump seal
minniemo705
06-24-2023 10:54:58
Quick question- does anyone ever put any lube of some sort on the new water pump seal? I never have before, but wondering if I should. It's the seal on a g.
MMDEL
06-25-2023 14:46:13
 Re: U water pump seal in reply to minniemo705, 06-24-2023 10:54:58
You are right they used to sell water pump lube to put in the radiator. I don't know if MM ever used it or talked about it in their operator or shop manuals.
molinegb
06-24-2023 18:14:38
At one time there was waterpump lubricant that was added. MMDel may remember.
MMDEL
06-24-2023 12:03:34
NO. Lube is in the carbon seal. Don't know if you machined the hub surface where the seal mates to ( good idea ) especially if it not too flat anymore. It may drip for awhile. Till it wears in. Be sure your weep hole is cleaned out so it doesn't leak water in the crankcase.
MMDEL
minniemo705
06-24-2023 12:18:41
 Re: U water pump seal in reply to MMDEL, 06-24-2023 12:03:34
Thanks
