Minneapolis Moline Tractors Discussion Forum
MM Z Sediment Bowl and Seat Shock
mthopetractor
06-21-2023 06:06:51
Restoring a Minneapolis Moline Z so we bought a super original donor tractor, the sediment bowl on the donor tractor was a screw on type instead of the normal wire bail to secure the bowl, does anybody know if that was original or not.
Also when we sandblasted the seat spring and holder we found some red paint, any clues?
Third Party Image
MMDEL
06-22-2023 08:29:52
 Re: MM Z Sediment Bowl and Seat Shock in reply to mthopetractor, 06-21-2023 06:06:51
Hay fellows he's talking Z. They didn't have anything like that. ZA & ZB Yes.
MMDEL
jnf
06-21-2023 19:41:53
The spring is red from factory, at least on my UB and GB.
Ill John
06-21-2023 12:48:37
I think the seat shock was originally red, probably an updated seat suspension, that is the deluxe seat, could have been dealer installed
MMDEL
06-21-2023 12:43:28
The one you picture is the correct original type bowl. Jay in MN has those bowls. 507 .380.3707. As far as red paint the only red on the tractor is the wheels and if it has a PTO mechanical lift and brackets for a cultivator. Someone might have replaced the factory seat with a hydraulic ride seat and that would more that likely have been red.
MMDEL
molinegb
06-21-2023 07:23:27
Sediment bowl on U/Z/R. with hydraulics. Common to break on threads. Agco should have. Used on Cockshutt/MM/Oliver combines in 70s
J.Wondergem
06-21-2023 06:35:22
That's the type that's on my 1950 R. Not sure about original or not.
