Minneapolis Moline Tractors Discussion Forum
rim repair
Roger Roemen
06-10-2023 12:22:16
What do you all use to prep the inside of a tractor rim after it has been repaired?
Roger Roemen
06-11-2023 15:44:29
 Re: rim repair in reply to Roger Roemen, 06-10-2023 12:22:16
Thanks for the info
rustred
06-11-2023 06:36:05
just a light coat of primer is all i do. you dont need paint in there and if the paint is not cured the tube will stick to it and then be fun for the next time.
Ill John
06-10-2023 17:46:20
I use a self etching primer in a rattle can, then some ratt2le can I had left from something else and coat it really good
