Minneapolis Moline Tractors Discussion Forum
MM 335
Sacole3
06-09-2023 10:06:00
Hello. Im looking for a little help. I need rear axle seals for my 335. I cant find a part number anywhere and my local napa cant seem to cross reference a number c/r 394A212. Any help would be greatly appreciated. Thank you
Sacole3
06-12-2023 11:30:50
 Re: MM 335 in reply to Sacole3, 06-09-2023 10:06:00
Thank you for the replies. The housing is 10A13815. The outer axle seal does have the seal with clear markings of 394A212 C/R. I will have to get the bearing removed and take measurements. I was hoping to have parts in hand before I start removing everything. Thanks for the info.
sms
06-11-2023 10:54:04
If you can't find anything by application or cross reference you can do your best by size. I have bought seals from Baum Iron/Hydraulics by size. Seals listed by type and size in their catalog which you should be able to view online.
sms
06-11-2023 10:55:34
 Re: MM 335 in reply to sms, 06-11-2023 10:54:04
They also used to have tech support that may be able to help you.
BMG1
06-09-2023 16:22:51
Depends on what rear end casting is in your tractor.
Utility w/ 10B6505 rear end casting uses 10A7246 which crosses to a CR # 23844
Utility w/ 10B13815 rear end casting uses 10A11325 which is no longer available and doesn't have a CR cross reference.
Universal Row Crop all used 10A11324 which is no longer available and doesn't have a CR cross reference either.
yonson
06-09-2023 13:08:24
Tractor serial# tag is on right side of transmission case. I think the number you posted is the engine serial# which is difficult to research.
yonson
06-09-2023 13:09:51
 Re: MM 335 in reply to yonson, 06-09-2023 13:08:24
Sorry, wrong post -
