Minneapolis Moline Tractors Discussion Forum
MM Twin City carb
Troyer
06-08-2023 03:34:38
Does anyone know if the Zenith U-6 carb is still available somewhere for a 21-32 or know of anyone that deals in old carburetors? This tractor has the air cleaner that hangs on the front manifold stud and is outside the hood. If the U-6 is no longer available what would be the replacement?
Duey C
06-10-2023 17:26:04
 Re: MM Twin City carb in reply to Troyer, 06-08-2023 03:34:38
Strombergof.com is gone. Stan passed away two years ago.
I vote for the cast iron Schebler TTX-23 for your mid-late 1930 21-32 if you can't find a U-6.
The mismatched heights baffles me but I'm no expert.
molinegb
06-08-2023 06:42:11
Motor serial 102106-900297 Stromberg UT2.900298-901057 Zenith K5A. 901058 and later Marvel
Troyer
06-08-2023 06:53:35
 Re: MM Twin City carb in reply to molinegb, 06-08-2023 06:42:11
I appreciate the info. I'll make a note of it. Could you point me in a direction as to where to begin looking for one?
molinegb
06-08-2023 07:10:52
 Re: MM Twin City carb in reply to Troyer, 06-08-2023 06:53:35
Which carb?
Troyer
06-08-2023 09:55:28
 Re: MM Twin City carb in reply to molinegb, 06-08-2023 07:10:52
Let's try to find the Stromberg UT2. I failed to mention that the air cleaner is cast iron with FT cast into it, which may not make a difference which carb was used. And that was the first indication that the carb that was with the tractor may not be the right one. The air cleaner port and the intake on the carb are offset by an inch with carb being on low side and the air cleaner port on the upper and only 2 inches apart. Any connecting hose will kink with this set-up.
molinegb
06-08-2023 10:34:38
 Re: MM Twin City carb in reply to Troyer, 06-08-2023 09:55:28
Have seen on Ebay. Is a brass carb and a poor one. similar ti a Model T one. Try old site www.strombergof.com
molinegb
06-08-2023 05:32:21
Don't recall any MM/TC using a Zenith carb. Stromberg or Marvel. Serial #?
Troyer
06-08-2023 05:49:45
 Re: MM Twin City carb in reply to molinegb, 06-08-2023 05:32:21
Serial #153560
