4160
hello..who is the best contact to supply parts for my 1942 uts?? I'm in the uk so would need a reliable supplier to send etc...is molineparts the best bet? I need water pump seal kit,tapper screw adjusters,halfshaft wheel nut,rear brake drum oil seals,thermostat etc..thanks
MM did not make a UTS in 1942. Check serial number. Most parts are common to all years. Have most all years of UTS except 1954 and the ones shipped to UK and
repowered with the Dorman and Meadows diesels. 1938-41 red nose. 38-40 KEC 41 -47 KEF motor.
1941 was a red nose. 316 prefix makes a 43. Wartime model. Have one with cast steering wheel. Was on steel and has no dash,just a blank. Would have new water
pump seal.
